AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
How to Add/Delete/Modify composite rule on FDO Layer using AutoCAD.NET?
1 REPLY 1
dr5156
306 Views, 1 Reply
Hi
Dayalan
1 REPLY 1
Daniel.Du
in reply to: dr5156
The style of layer(with different rules) are resources in Map 3D, i.e. layer definition, you can edit it with resource services, please refer to this tool(with source code) as am example.
https://github.com/ADN-DevTech/map-resource-explorer
Daniel Du
Developer Technical Services
Autodesk Developer Network
”Boost
