AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
How can I build topology using VBA?
5 REPLIES 5
475 Views, 5 Replies
Hello. How can I build topology using VBA? Does exist equivalent objectarx/vlisp functions tpm_???? in VBA? (e.g. tpm_mntbuild, tpm_acload, etc.) Thanx Maciej Kowalewski
5 REPLIES 5
LochDhu
The topology functions are not exposed in the ActiveX API.
Scott
May I ask Why???
palslayer2
Because the Managers at Autodesk do not consider VBA a real Language that needs an full API, they rather slap a new feature in, rather then take the time to do it right
this means that it's not possible to use any topology functions from VBA (like add new link, join links, etc.)?
LochDhu
Correct. However, Map 2006 has a .NET API that provides access to topology. Download the Map 2006 ARX SDK to see examples.
Scott
”Boost
