I want to generate graphics from a API-Button in a Map 3D form. Is this possible?
The goal is to choose an object in the form and generate the graphics in the map with some parameters (ex. extension of the object).
So I would like to use the geometry of the object and I want to use the same parameters as I have in "advanced generate graphics" dialogue (easting, northing, with, heigth).
Thank you for some ideas.
It can be done.
Check out the developer samples:
C:\Program Files\Autodesk\AutoCAD Map 3D 2013\Development\Samples
16_Dialog_Button will show how to create an API-Programmable Control on a form.
135_GenerateGraphics will show how to generate graphics.
Some notes:
1. GraphicsGeneratorFactory.Instance is obsolete. Instead, use Application.Services.GetService<IGraphicsGenerator>().
2. Create an Autodesk.Map.IM.Graphic.Polygon to represent the area within which you want to generate graphics. Perhaps you can get the bounding box of the feature in the form and create a polygon based on those extents.
3. Use IFilterSetter to then apply the polygon as the extents for the graphics generation.
Here's some code:
IGraphicsGenerator gg = Application.Services.GetService<IGraphicsGenerator>(); //Confirm that gg.DisplayModel is not null IFilterSetter filterSetter = FilterSetterFactory.Create(gg.DisplayModel); filterSetter.OnlyOnTopobaseLayers = false; filterSetter.TransformCoordSysInFilter = true; //Somehow get the extents of the area within which you want to gg var polygon = new Polygon { new LinePoint(SomeMinPoint.X, SomeMinPoint.Y), new LinePoint(SomeMaxPoint.X, SomeMinPoint.Y), new LinePoint(SomeMaxPoint.X, SomeMaxPoint.Y), new LinePoint(SomeMinPoint.X, SomeMaxPoint.Y), new LinePoint(SomeMinPoint.X, SomeMinPoint.Y) }; filterSetter.ApplyViewport(polygon); //Set the progress bar, draw, reset the progress bar, and dispose per the 135 code sample
Hi Thomas,
Did you check the refence code / post by Drew here ?
Hope that helps you in achieving what you want.
additional question about the displaymodel.
I want to change the display model from "EBL_ALKIS__schwarz/Weiss" to "EBL_ALKIS_farbig"
and use following source:
Dim gg As IGraphicsGenerator = GraphicsGeneratorFactory.Instance
gg.DisplayModel.Definition.Name = "EBL_ALKIS_farbig"
If gg.DisplayModel Is Nothing Then
Me.Application.MsgBox("No Display Model set")
Return
End If
But the flyouts from gg.DisplayModel show all the time "EBL_ALKIS__schwarz/Weiss"
Did you have an idea?
Regards Bjoern
Hi:
I haven't tried this, but I would guess that you actually need to get the DisplayModel and not simply change the name of the currently assigned display model. There's a display model repository interface - maybe you have to grab the display model from that?
Does this work?
string resourceId = gg.DisplayModelRepository.GetResourceIdForDisplayModelFileName("EBL_ALKIS_farbig"); gg.DisplayModel = gg.DisplayModelRepository.Load(resourceId);
thanks for the tip.
I could handle this problem with your help .
Instead of the name of the display models I have used the path:
ResourceId = gg.DisplayModelRepository.GetResourceIdForDisplayModelFileName("\\MA22-AP-013\Topobase\Darstellungsmodelle\EBL_ALKIS_farbig\EBL_ALKIS_farbig.tbdm")
Now I have another problem .
I want to build a map 2000x2000 meters and pass the coordinate of the center.
I use AutoCAD Map 2012 and can not use the ifiltersetter.
Dim filterSetter As ifiltersetter = Topobase.Display.DisplayModelManagement.FilterSetterFactory.Create(gg.DisplayModel)
filterSetter.OnlyOnTopobaseLayers = False
filterSetter.TransformCoordSysInFilter = True
Can I use the DRAW command (VBSample135) with parameter "center-coordinate" and "width/height"?
Or did you know a better way?
Regards Björn
Hi:
Why can't you use IFilterSetter in 2012? It looks available to me.
If IFilterSetter is not working, perhaps you can first zoom to the area of interest and then generate graphics:
http://through-the-interface.typepad.com/through_the_interface/2008/06/zooming-to-a-wi.html
