AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
FDO object properties through GetEntity
4 REPLIES 4
1840 Views, 4 Replies
Hi all! I have some trouble - now I developing some library for Autocad Civil 3D 2011: we are have connect to MS SQL Server base with some tables - it's our layers with geometry and some other columns. When user press button on our panel - we have opportunity select one FDO object on our map. After this our library will show layer name of selected object and names and values of other columns in table of selected object:
[CommandMethod("SHOWPROP")]
        public static void ShowProperties()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            MgFeatureReader reader = null;
            try
                // Ask the user to select FDO object
                PromptEntityOptions peo =
                  new PromptEntityOptions("\nSelect FDO object");
                peo.SetRejectMessage("\nMust be a FDO object.");
                peo.AllowNone = false;
                PromptEntityResult per = ed.GetEntity(peo);
                if (per.Status != PromptStatus.OK)
                    return;
                ObjectId srcId = per.ObjectId;
                Transaction tr =
                  doc.TransactionManager.StartTransaction();
                using (tr)
                    AcMapMap currentMap = AcMapMap.GetCurrentMap();
                    MgLayerCollection LayerCol = currentMap.GetLayers();
                    Autodesk.Gis.Map.Platform.AcMapLayer maplayer=null;
                    if (per.ObjectId != ObjectId.Null)
                        DBObject obj = tr.GetObject(per.ObjectId, OpenMode.ForRead);
                        if (obj != null)
                            ed.WriteMessage("\n" + "Type: " + obj.GetType().ToString());
                            ed.WriteMessage("\n" + "RXClassName: " + obj.GetRXClass().Name.ToString());
                            ed.WriteMessage("\n" + obj.Database.GeoDataObject.ToString());
                            Entity ent = (Entity)tr.GetObject(srcId, OpenMode.ForRead);
                            ed.WriteMessage("\n" + AcMapFeatureEntityService.GetLayer(per.ObjectId).ToString());
                            maplayer = AcMapFeatureEntityService.GetLayer(per.ObjectId);
                            ed.WriteMessage("\n" + "Layer name: " + maplayer.Name);
                            ed.WriteMessage("\n" + "Layer: " + maplayer.FeatureClassName.ToString());
                            //I don't know how initialize reader :(
                            //reader = ?????
                            MgClassDefinition classDef = maplayer.GetClassDefinition();
                            MgPropertyDefinitionCollection propertyDefs = classDef.GetProperties();
                            foreach (MgPropertyDefinition propertyDef in propertyDefs)
                                if (propertyDef.Name != ClassSystemProperties.SessionId)
                                    switch (propertyDef.GetPropertyType())
                                        case MgFeaturePropertyType.DataProperty:
                                            MgDataPropertyDefinition dataProp = propertyDef as MgDataPropertyDefinition;
                                            if (dataProp != null)
                                                // Set default value.
                                                string value = "(null)";
                                                    // Reads the value from featureReader according to DataType.
                                                    switch (dataProp.GetDataType())
                                                        case MgPropertyType.String:
                                                            //Next string not work :(
                                                            //value = reader.GetString(propertyDef.Name);
                                                            break;
                                                        case MgPropertyType.Double:
                                                            //value = reader.GetDouble(propertyDef.Name).ToString();
                                                            break;
                                                        case MgPropertyType.Int16:
                                                            //value = reader.GetInt16(propertyDef.Name).ToString();
                                                            break;
                                                        case MgPropertyType.Int32:
                                                            //value = reader.GetInt32(propertyDef.Name).ToString();
                                                            break;
                                                        case MgPropertyType.Int64:
                                                            //value = reader.GetInt64(propertyDef.Name).ToString();
                                                            break;
                                                        case MgPropertyType.Boolean:
                                                            //value = reader.GetBoolean(propertyDef.Name).ToString();
                                                            break;
                                                        default:
                                                            break;
                                                //Util.PrintLn(propertyDef.Name + " = " + value);
                                                ed.WriteMessage("\n" + propertyDef.Name + " = " + value);
                                            break;
                                        case MgFeaturePropertyType.AssociationProperty:
                                            break;
                                        default:
                                            break;
                    tr.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                ed.WriteMessage("\nException: {0}", ex.Message);
I know - somebody will say - "see Feature Inspector code in ObjectARX SDK!" but this example not suitable for this case. I do not have selected area on my map and old ideas for initialize FeatureReader not work 😞 Please, help somebody.
P.S. Sorry for my English
4 REPLIES 4
Hi vipwall,
I didn't scan through each line of your code snippet, but here is the general approach of FDO Feature selection using AutoCAD Map 3D Geospatial Platform API :
1. //Get Map selection set from AutoCAD selection set
   // code Snippet below :
SelectionSet selSet = selResult.Value;
MgSelectionBase selectionBase = AcMapFeatureEntityService.GetSelection(selSet);
2. // Use the GetSelectedFeatures() to get the MgFeatureReader object
   // Code Snippet below :
MgFeatureReader ftrRdr = selectionBase.GetSelectedFeatures(ParkPointLayer, ParkPointLayer.FeatureClassName, false);
try
while(ftrRdr.ReadNext())
string parkPointName = ftrRdr.GetString("STNAME"); // this this just a demo, change this according to your data field
ed.WriteMessage(
"\n Park Name :"+ parkPointName.ToString());
Int32 FeatureID = ftrRdr.GetInt32("FeatId"); // this this just a demo, change this according to your data field
ed.WriteMessage(
"\n Feature ID :"+ FeatureID.ToString());
Hope this helps.
P.S. - We have plenty of code snippet in ADN - Autodesk Developer Network (http://adn.autodesk.com/) site on the same. I am not sure if you are an ADN member and have access to ADN page. You might get some code snippet by Googling,  from the Map 3D SDK samples and SDK docs.
Hi, Partha Sarkar!
Great thanks for you! I continued my research and the result was the following code. It works correctly:
    MgFeatureReader reader;
    PromptSelectionResult selectionRes;
    selectionRes = ed.SelectImplied();
    PromptSelectionOptions selectionOpts = new PromptSelectionOptions();
    selectionOpts.MessageForAdding = "Select single FDO object";
    selectionOpts.SingleOnly = true;
    selectionRes = ed.GetSelection(selectionOpts);
    if ((selectionRes.Status == PromptStatus.Error)||(selectionRes.Status == PromptStatus.Cancel))
        return;
    if (selectionRes.Value.Count!=1)
        ed.WriteMessage("Need select only single object!");
        acadApp.UpdateScreen();
        return;
    Transaction tr = doc.TransactionManager.StartTransaction();
    try
    ObjectId[] objIds = selectionRes.Value.GetObjectIds();
    foreach (ObjectId objId in objIds)
        DBObject obj = tr.GetObject(objId, OpenMode.ForRead);
        Entity ent = (Entity)obj;
        //If selected object is not FDO object
        if (ent.Layer!="*ACMAPDMGISENTITIES")
            obj.Dispose();
            tr.Abort();
            return;
        // This time access the properties directly
        ed.WriteMessage("\nType:        " + ent.GetType().ToString());
        Autodesk.Gis.Map.Platform.AcMapLayer maplayer = AcMapFeatureEntityService.GetLayer(objId);
        ed.WriteMessage("\n" + maplayer.ToString());
        ed.WriteMessage("\n" + maplayer.FeatureClassName.ToString());
        MgSelectionBase selectionBase = AcMapFeatureEntityService.GetSelection(selectionRes.Value);
        reader = selectionBase.GetSelectedFeatures(maplayer, maplayer.FeatureClassName, false);
        while (reader.ReadNext())
                                        break;
                                        break;
                                        break;
                                        break;
                                        break;
                                        break;
                                    default:
                                        break;
                            break;
                            break;
                        default:
                            break;
        obj.Dispose();
    tr.Commit();
        ed.WriteMessage(ex.Message);
        tr.Abort();
 When we select some object on our map  - program check - it is FDO object or not and show object properties. May be this code will help somebody.
I am glad to know that code snippet was useful to you 🙂
Cheers,
hosneyalaa
@Anonymous   and @Anonymous Hi all
Nice and cool code
I am not experienced Map3d
a question How do you set a value instead of extracting it for example is that possible
Change this
value=reader.GetString(propertyDef.Name)
With
                                        value = reader.SetString(propertyDef.Name);
                                        break;
Thanks all
”Boost
