Any one have a sample code to export Lines, arcs and plines and their obj data to SDF.
so far all I have been able to do is create a selectset of the objects.
thanks in advance.
check >>>this<<< class ("Using the FDO API in C# .NET" by Scot McFarlane) from AU2009. Yes, it's some time ago and you may need to adopt some signatures used within this class, but it's a real good overview on how to use the FDO-API.
HTH, - alfred -
The following articles with code samples will be useful to you :
Export DWG to SDF using Autodesk.Gis.Map.ImportExport.Exporter API
Exporting DWG to SDF using *.epf file using Map 3D API
Cheers
