AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Error:Automation error [-2147467259 (80004005)]
2 REPLIES 2
vedantgoyal
849 Views, 2 Replies
Can anyone tell me why i m getting a automation error
My condition gets satisfied and after that i get automation error msgbox
What am i doing wrong?
For Each acadOBJ In ThisDrawing.ModelSpace
boolVal = ODrcs_PB.Init(acadOBJ, True, False)
Do While ODrcs_PB.IsDone = False
If ODrcs_PB.Record.Item(iTypeFieldIndex).Value = PillarType Then
MsgBox "Sucess"
ODrcs_PB.Next
Loop
Next
2 REPLIES 2
mateaus
in reply to: vedantgoyal
I've got the same problem to do this
robapp.Project.PrintEngine.SaveReportToFile fichier_sortie, I_OFF_RTF_JPEG
but the command has worked good before.
I don't know what has been changed.
Daniel.Du
in reply to: mateaus
Which version of Map 3D are you using? 32bit or 64bit? Would you please provide a complete code snippet for test?
Since you are asking VBA questions, I would suggest you to migrate your VBA program to VB.net, please take a look at this blog:
http://through-the-interface.typepad.com/through_the_interface/2010/02/updated-devtv-autocad-vba-to-...
Daniel Du
Developer Technical Services
Autodesk Developer Network
”Boost
