i am trying to read the Object data records. i can see the object data table and definitions and field names, but cannot seem to get to the value of each field. What am i missing?
Dim
ed AsEditor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Dim pe AsNewPromptEntityOptions("Select Object..")
Dim pr AsPromptEntityResult= ed.GetEntity(pe)
If pr.Status = PromptStatus.OK ThenUsing trans AsTransaction = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction()
Dim ent AsEntity = trans.GetObject(pr.objectid, OpenMode.ForRead)
Dim myTables As Autodesk.Gis.Map.ObjectData.Tables = Autodesk.Gis.Map.HostMapApplicationServices.Application.ActiveProject.ODTables
Dim myRec As Autodesk.Gis.Map.ObjectData.Records = myTables.GetObjectRecords(0, ent.ObjectId, Autodesk.Gis.Map.Constants.OpenMode.OpenForRead, True)
Dim myFieldDef As Autodesk.Gis.Map.ObjectData.FieldDefinitions' Dim FieldDef As Autodesk.Gis.Map.ObjectData.FieldDefinitionForEach rec As Autodesk.Gis.Map.ObjectData.RecordInmyRec
Dim table As Autodesk.Gis.Map.ObjectData.Table= myTables(rec.TableName.ToString)
myFieldDef = table.FieldDefinitions
Dim i AsIntegerWhilei < myFieldDef.Count
MsgBox(myFieldDef.Item(i).Name)
i = i + 1
EndWhileNextEndUsingEndIf
Dim i As Integer = 0 While i < myFieldDef.Count 'you first have to check the datatype of the column 'then you can do one of these statements (or more like boolean ...) debug.print rec(i).Int32Value.ToString debug.print rec(i).DoubleValue.ToString debug.print rec(i).StrValue MsgBox(myFieldDef.Item(i).Name) i = i + 1 EndWhile
HTH, - alfred -
please help
I have gone through
for help on extracting ObjData from an object and it is over my head.
I have created referance to ManagedMapApi.dll
I have Imports Autodesk.Gis.Map.ObjectData.
now what do I need to do to extract OD from my objects.
Dim activeProject AsProject.ProjectModel = mapApp.ActiveProject Dim table As ObjectData.Table = tableList("table1")
why not continueing >>>here<<<?
The thread-title says "Does it have Object Data" ==> is that also your problem? Or do you have another one?
- alfred -
Hey Alfread...looks like you are burning the midnight oil as well.
anyway when I use
Dim fieldDefs AsAutodesk.Gis.Map.ObjectData.FieldDefinition = table.FieldDefinitions
Dim recs As ObjectData.Records
recs = table.GetObjectTableRecords(0, objId, Constants.OpenMode.OpenForRead,True)
from the sample,
I get a bunch of errors.
Error 1 'table' is ambiguous, imported from the namespaces or types 'Autodesk.Gis.Map.ObjectData, ADOX, Autodesk.AutoCAD.DatabaseServices'.
Error 2 Type 'ObjectData.Records' is not defined.
Error 3 'table' is ambiguous, imported from the namespaces or types 'Autodesk.Gis.Map.ObjectData, ADOX, Autodesk.AutoCAD.DatabaseServices'.
Error 4 'OpenMode' is not a member of 'Microsoft.VisualBasic.Constants'.
besides all I have is a selection set and just one table.
All I want to do is get the object data of an object, and not all the objects in the selection may have object data.
>> ADOX,
that message means you have 3 namespaces having an item "table", so the compiler does not know how to do with them.
Either you be more careful on top of your code-file with the number of "import"-statements or you write the full namespace-part to these lines.
And every time you get something like "not a member of" you also can try to use the full namespace for that object (or this enumeration).
- alfred -
Thank for your patients, I am still getting my feet wet with vb.net
Bottom line, specifically what do I need to do to get this sample code to work.
After that, I can step through the debugger to see exactly how it works.
is it just a sample solution you are currently working (so you can upload your sources/projects/solution-files) or can't you upload it?
If first ... would be much easier to describe what to change 😉
- alfred -
I am reading a CAD drawing, creating a MDB file and writing out the data.
However, I will comment out the call to the other routines to simplify it.
The section call is TextExtractOBJData and I am passing a selection set.
the dwg file Text.dwg is in the Vb.net project folder.
thanks for looking into this. Any suggestions or recommendations are welcomed.
I did what I could do, but some objects are unclear to me, e.g. the object "tables" you reference but never declared or assigned anything to it. That's your job.
Therefor (and for the reason I currently have 64bit running) I could not start anything as you have some ADOX-/MDB-access.
A tip for the future: use "strict on" in your project settings. It's a little bit more code to write as then late-binding is disabled by default and you have to use some TryCast or CType coding, but the code will run more stable as you see type-mismatches while code-writing and not as exceptions at customer-place. 😉
Good luck, - alfred -
What you see is simply a cut and paste of the sample from the Autodesk site.
So I too do not know what the object "Table" refers too.
basically at this point all I want is a routine that I can pass an object and it returns it's object data.
thanks for helping
EUREKA, I filnally got it !!!!
I did some more digging in the documentation and pulled all the pieces together.
just in case some other poor sap like me needs to extract object data.
Here is the code.
References are AcDbMgd, AcMgd, managedMapApi
Imports System Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.Gis.Map.ObjectData Imports Autodesk.Gis.Map Private Sub TestExtractOBJData(ByRef acSSet As SelectionSet) Dim doc As Document = Application.DocumentManager.MdiActiveDocument() Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim mapApp As MapApplication mapApp = HostMapApplicationServices.Application Dim activeProject As Autodesk.Gis.Map.Project.ProjectModel = mapapp.ActiveProject Dim tableList As Autodesk.Gis.Map.ObjectData.Tables = activeProject.ODTables 'get specific table = "MyTable" Dim table As ObjectData.Table = tableList("MyTable") 'Dim acEditor As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor 'start a transaction Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = db.TransactionManager Dim myT As Transaction = tm.StartTransaction() Using myT Try 'loop through object in the selection set For Each sobj As SelectedObject In acSSet Dim ent As Entity = myT.GetObject(sobj.ObjectId, OpenMode.ForRead) If TypeOf ent Is DBText Then Dim tt As DBText = DirectCast(ent, DBText) Dim fieldDefs As ObjectData.FieldDefinitions = table.FieldDefinitions Dim recs As ObjectData.Records recs = table.GetObjectTableRecords(0, sobj.ObjectId, Constants.OpenMode.OpenForRead, True) 'check if there are records for the selected table If (recs.Count() > 0) Then For Each rec As ObjectData.Record In recs 'get object data for each record in table For i As Integer = 0 To rec.Count() - 1 Dim val As Autodesk.Gis.Map.Utilities.MapValue val = rec(i) Dim fieldDef As ObjectData.FieldDefinition fieldDef = fieldDefs(i) ed.WriteMessage(vbNewLine + fieldDef.Name + ": ") Select Case val.Type Case Constants.DataType.Character ed.WriteMessage(val.StrValue) Case Constants.DataType.Integer ed.WriteMessage(val.Int32Value.ToString) Case Constants.DataType.Point ed.WriteMessage("point") Case Constants.DataType.Real ed.WriteMessage(val.DoubleValue.ToString) Case Else ed.WriteMessage("undefined") End Select Next Next End If recs.Dispose() End If Next myT.Commit() Catch ex As Autodesk.AutoCAD.Runtime.Exception ed.WriteMessage(vbLf & "{0}" & vbLf & "{1}", ex.Message, ex.StackTrace) End Try End Using End Sub
Big thanks to alfred for spending time and patients with me
cheers
That's how development works 😉
Great you could solve it and that you published it here for others (not all do that)!
- alfred -
OK great. Now that it finds the Object Data I want to highlight the drawing objects (perhaps by changing the object's color) that have an empty field for their Object Data record (i.e. the data was not entered and the field value and is now blank or empty).
Once those objects are identified on the drawing (perhaps by turning their color to RED) , the Object Data for these drawing objects can then be altered to contain a non-blank entry.
