AutoCAD Map 3D Developer
8 Kudos
Post 11 of 16
Re: Does it have Object Data? vb.net
04-24-2012 11:47 AM in reply to: Alfred.NESWADBA
I am reading a CAD drawing, creating a MDB file and writing out the data.
However, I will comment out the call to the other routines to simplify it.
The section call is TextExtractOBJData and I am passing a selection set.
the dwg file Text.dwg is in the Vb.net project folder.
thanks for looking into this. Any suggestions or recommendations are welcomed.
1,210 Kudos
Post 12 of 16
04-24-2012 01:47 PM in reply to: mfernandes
I did what I could do, but some objects are unclear to me, e.g. the object "tables" you reference but never declared or assigned anything to it. That's your job.
Therefor (and for the reason I currently have 64bit running) I could not start anything as you have some ADOX-/MDB-access.
A tip for the future: use "strict on" in your project settings. It's a little bit more code to write as then late-binding is disabled by default and you have to use some TryCast or CType coding, but the code will run more stable as you see type-mismatches while code-writing and not as exceptions at customer-place. :smileywink:
Good luck, - alfred -
Alfred NESWADBA
8 Kudos
Post 13 of 16
04-24-2012 07:21 PM in reply to: mfernandes
What you see is simply a cut and paste of the sample from the Autodesk site.
So I too do not know what the object "Table" refers too.
basically at this point all I want is a routine that I can pass an object and it returns it's object data.
thanks for helping
8 Kudos
Post 14 of 16
04-25-2012 12:25 AM in reply to: mfernandes
EUREKA, I filnally got it !!!!
I did some more digging in the documentation  and pulled all the pieces together.
just in case some other poor sap like me needs to extract object data.
Here is the code.
References are AcDbMgd, AcMgd, managedMapApi
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.Gis.Map.ObjectData
        Private Sub TestExtractOBJData(ByRef acSSet As SelectionSet)
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument()
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim mapApp As MapApplication
            mapApp = HostMapApplicationServices.Application
            Dim activeProject As Autodesk.Gis.Map.Project.ProjectModel = mapapp.ActiveProject
            Dim tableList As Autodesk.Gis.Map.ObjectData.Tables = activeProject.ODTables
            'get specific table = "MyTable"
            Dim table As ObjectData.Table = tableList("MyTable")
            'Dim acEditor As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
            'start a transaction
            Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = db.TransactionManager
            Dim myT As Transaction = tm.StartTransaction()
            Using myT
                Try
                    'loop through object in the selection set
                    For Each sobj As SelectedObject In acSSet
                        Dim ent As Entity = myT.GetObject(sobj.ObjectId, OpenMode.ForRead)
                        If TypeOf ent Is DBText Then
                            Dim tt As DBText = DirectCast(ent, DBText)
                            Dim fieldDefs As ObjectData.FieldDefinitions = table.FieldDefinitions
                            Dim recs As ObjectData.Records
                            recs = table.GetObjectTableRecords(0, sobj.ObjectId, Constants.OpenMode.OpenForRead, True)
                            'check if there are records for the selected table
                            If (recs.Count() > 0) Then
                                For Each rec As ObjectData.Record In recs
                                    'get object data for each record in table
                                    For i As Integer = 0 To rec.Count() - 1
                                        Dim val As Autodesk.Gis.Map.Utilities.MapValue
                                        val = rec(i)
                                        Dim fieldDef As ObjectData.FieldDefinition
                                        fieldDef = fieldDefs(i)
                                        ed.WriteMessage(vbNewLine + fieldDef.Name + ": ")
                                        Select Case val.Type
                                            Case Constants.DataType.Character
                                                ed.WriteMessage(val.StrValue)
                                            Case Constants.DataType.Integer
                                                ed.WriteMessage(val.Int32Value.ToString)
                                            Case Constants.DataType.Point
                                                ed.WriteMessage("point")
                                            Case Constants.DataType.Real
                                                ed.WriteMessage(val.DoubleValue.ToString)
                                            Case Else
                                                ed.WriteMessage("undefined")
                                        End Select
                                    Next
                                Next
                            End If
                            recs.Dispose()
                        End If
                    Next
                    myT.Commit()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    ed.WriteMessage(vbLf & "{0}" & vbLf & "{1}", ex.Message, ex.StackTrace)
                End Try
            End Using
        End Sub
 Big thanks to alfred for spending time and patients with me
cheers
1,210 Kudos
Post 15 of 16
04-25-2012 11:58 AM in reply to: mfernandes
That's how development works :smileywink:
Great you could solve it and that you published it here for others (not all do that)!
- alfred -
Alfred NESWADBA
0 Kudos
Post 16 of 16
12-21-2012 06:51 AM in reply to: mfernandes
OK great. Now that it finds the Object Data I want to highlight the drawing objects (perhaps by changing the object's color) that have an empty field for their Object Data  record (i.e. the data was not entered and the field value and is now blank or empty).
Once those objects are identified on the drawing (perhaps by turning their color to RED) , the Object Data for these drawing objects can then be altered to contain a non-blank entry.
