AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Display Oracle Spatial data to AUD Screen
4 REPLIES 4
549 Views, 4 Replies
Hi
I fetched Geometry data from Oracle Spatial Database but now i need to show/display the same to AUD Modal Space(i.e. AUD Screen).
I am fetching Oracle Spatial Data using custom code by using FDO.
This is URGENT.
Rajeev.
4 REPLIES 4
What is an "AUD Screen"?
Hi
By AUD Screen i mean to say the Modal Space.
Let`s supoose we have a drawing file being shown on the Map Area, now i have geometry data fetched from oracle spatial database which is a polygon.
I want to show this polygon on the drawing file. I supoose that we need to create a layer and then add it. But not sure weather thats the correct approach and also how do we do it.
Any sample code will help a lot.
Rajeev.
Hi
i am trying to get the current layer and then creating a new layer by adding my geomtry data to this layer but facing issues.
the custome code is
AcMapMap map = AcMapMap.GetCurrentMap();
AcMapLayer layer = (AcMapLayer)map.GetLayers().GetItem(0);
On code AcMapMap.GetCurrentMap(); there is no current map is getting rendered hence error on the 2nd line as "Index was out of bounds".
Please let me know as to how can i get the current map layer or how can i add a new layer.
Rajeev.
I would recommend you take another look at the samples here: .....\Autodesk\Map ObjectARX SDK 2012\Map Samples\Platform.( or whatever your current flavor is)
I will be of little help to you. Some years ago I decided to work with the AutoCad objects directly and not use FDO.
I developed my own code for the translation between Oracle's SDO_GEOMETRY format and the AutoDesk format. It has worked for years and since then I only use "Map" for display and visualization.
Good luck to you...
dennis
”Boost
