Hi
I fetched Geometry data from Oracle Spatial Database but now i need to show/display the same to AUD Modal Space(i.e. AUD Screen).
I am fetching Oracle Spatial Data using custom code by using FDO.
This is URGENT.
Rajeev.
Hi
By AUD Screen i mean to say the Modal Space.
Let`s supoose we have a drawing file being shown on the Map Area, now i have geometry data fetched from oracle spatial database which is a polygon.
I want to show this polygon on the drawing file. I supoose that we need to create a layer and then add it. But not sure weather thats the correct approach and also how do we do it.
Any sample code will help a lot.
Rajeev.
Hi
i am trying to get the current layer and then creating a new layer by adding my geomtry data to this layer but facing issues.
the custome code is
AcMapMap map = AcMapMap.GetCurrentMap();
AcMapLayer layer = (AcMapLayer)map.GetLayers().GetItem(0);
On code AcMapMap.GetCurrentMap(); there is no current map is getting rendered hence error on the 2nd line as "Index was out of bounds".
Please let me know as to how can i get the current map layer or how can i add a new layer.
Rajeev.
I would recommend you take another look at the samples here: .....\Autodesk\Map ObjectARX SDK 2012\Map Samples\Platform.( or whatever your current flavor is)
I will be of little help to you. Some years ago I decided to work with the AutoCad objects directly and not use FDO.
I developed my own code for the translation between Oracle's SDO_GEOMETRY format and the AutoDesk format. It has worked for years and since then I only use "Map" for display and visualization.
Good luck to you...
dennis
