AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
display attributes on the screen as label for point data
3 REPLIES 3
newautocad123
643 Views, 3 Replies
I have imported a shp to dwg. It has the object data attibutes.
Suppose I have a point for cities shp imported to dwg. The attribute has name of the city. How can I display the name of the city to each point on the layer of dwg file. It can be a Mtext near the points.
Thanks.
3 REPLIES 3
Output as :city-dwg.jpg
Input dwg file:
Daniel.Du
in reply to: newautocad123
It is a feature if Map 3D 2013, please refer to http://docs.autodesk.com/MAP/2013/ENU/index.html?url=filesMAPLRN/GUID-FF9D065C-3A6A-4523-BDFF-7842ED...
Daniel Du
Developer Technical Services
Autodesk Developer Network
newautocad123
in reply to: Daniel.Du
I am using Autocad Map 3D 2012.
Thanks.
”Boost
