AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Debug problem
1 REPLY 1
316 Views, 1 Reply
Debug problem
I  am not able to debug a my vb.net project, Breakpoints do not work when debugging dll.
I am using Visual Studio 2008 and Autocad Map 3D API @ Winxp 32bit.
1 REPLY 1
Daniel.Du
Which version of Map 3D are you using? If you are using Map 3D 2012/2013, you will need VS2010. And also refer to this blog as well: http://through-the-interface.typepad.com/through_the_interface/2010/04/hitting-breakpoints-in-net-cl...
Daniel Du
Developer Technical Services
Autodesk Developer Network
”Boost
