AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Custom objects are modified when using the REGEN command
0 REPLIES 0
Message 1 of 1
thierry_prince
375 Views, 0 Replies
In our application we have some customs objects that derives from AcDbEntity.
For some reasons, we do some work when an object is modified and to know when, we simply test in the subClose() method (in the DBX module) if the object was opened for write.
All works fine with AutoCAD, but with Map, it appears that something open our entities for writing when the REGEN command is issued.
Perhaps it also true with other commands.
Why ?
Is it possible to invalidate this "modification" process in Map ?
Thanks for your ideas, help, answers...
Thierry
0 REPLIES 0
”Boost
