We have a VB application which was written with AutoCAD Map 2008 version.
We now need to re-write the entire application with AutoCAD Map 3D in VB.NET
Can anybody suggest some good specs/pointer?
And the way to do it...
Could you please tell me what code changes should I make?
I have used tried to check whether the object is AcDbPolyline or not.
But still it does not server the purpose.
Could you please be a little more specific in code perspective?
I hope this helps, it shows how to filter to any type of polylines during selection and then erase the selected items.
<Autodesk.AutoCAD.Runtime.CommandMethod("ADESK_erasePoly", Autodesk.AutoCAD.Runtime.CommandFlags.UsePickSet)> _ Public Shared Sub erasePoly() Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager Dim acDoc As Document = acDocMgr.MdiActiveDocument 'define a filter for objecttypes to be selectable 'we define now "*POLY*" so we select only 2D-Poly, 3D-Poly and LW-Poly Dim tFilter As SelectionFilter = New SelectionFilter(New TypedValue() _ {New TypedValue(DxfCode.Start, "*POLY*")}) 'Get the selected objects in the drawing area Dim acSSPrompt As PromptSelectionResult = acDoc.Editor.GetSelection(tFilter) 'If the prompt Status is OK, the objects are selected If acSSPrompt.Status = PromptStatus.OK Then Dim tDocLock As Autodesk.AutoCAD.ApplicationServices.DocumentLock = Nothing Dim tTrAct As Transaction = Nothing Try tDocLock = acDoc.LockDocument tTrAct = acDoc.Database.TransactionManager.StartTransaction For Each tObjID As ObjectId In acSSPrompt.Value.GetObjectIds If (tObjID.IsValid) AndAlso (Not tObjID.IsErased) Then 'just to make sure, the object is valid tTrAct.GetObject(tObjID, OpenMode.ForWrite).Erase() End If Next tTrAct.Commit() Catch ex As Exception Call MsgBox("Error occured." & vbNewLine & ex.Message) Finally If tTrAct IsNot Nothing Then tTrAct.Dispose() : tTrAct = Nothing If tDocLock IsNot Nothing Then tDocLock.Dispose() : tDocLock = Nothing End Try End If End Sub
- alfred -
Thanks a lot!!!
It worked, I am able to delete the polyline.
I could understand the mistakes that I was doing in the code.
I am attaching here a doc which mentions the process I am stuck in.
The dwg is a structure of a floor which contains space details in the form of cubes.
When I am trying to select a polyline and delete it, it is getting erased, but the text inside the polyline remains as it is.
I opened the Properties section to check what contains the text, I got there are two sections: Text & OD:DBLINK.
As far as I can understand if I am able to retrieve Text and delete it, I can delete the text also from dwg.
I am able to retrieve OD:DBLINK as:
Dim dbObj As DBObject = tTrAct.GetObject(id, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
odTable = odTables.Item("DBLINK")
Dim odrecords As ObjectData.Records = odTable.GetObjectTableRecords(Convert.ToUInt32(0), id, Constants.OpenMode.OpenForWrite, True)
MsgBox(odrecords(0).Item(0).StrValue) - This shows me the value KSOPHJ022B352
But I do not know how to retrieve the Text column from the properties file and delete it.
Please let me know if my concept is wrong somewhere.
can you upload a drawing with some of the geometry (holding object-data).
As I don't know how the object-data is structured I can't tell you now if you can find the text by od.
As long as the structure is as clean as you showed in the screenshots it is also easy to find the text inside the polyline-rectangles as you only have to scan through all the text-objects and look which mid-point of the text is inside a specific rectangle.
An option may also be to use a selectionset with option "WindowPolygon" using the vertices if the rectangle, but in this case you need to have the text visible on screen (at least within the current REGEN-area, otherwise the selection on screen (to be used with WindowPolygon) can't find the text.
- alfred -
I have attached here the dwg file.
Let me know if that is sufficient to get the Text or do I need to provide anything else.
thx for the drawing + the doc, makes it quite easier to understand for me.
A last question to make sure that I don't start into the wron direction. You stated.
Do you mean "how to delete the text-object from the drawing"? Or do you look for a way to erase a object-data-record when you deleted an object (your polyline)?
- alfred -
As I have displayed in the doc, when I select the text object polyline, that gets deleted, but the text remains the same.
What I want, when I select the polyline and delete it, the associated text also should be deleted from the dwg.
For that what I understood, if I am able to retrieve the Text from the Properties and I am able to delete it, it would delete the text from the dwg as well.
I am not sure about the difference between deleting only the text from the dwg and deleting object-data-record.
Deleting only the text - does that mean the text would disapear from the dwg but if I click on the properties window for the text, the text would still appear on the properties window?
Deleting object-data-records - the text as well as entry from the properties window, both would be lost?
Is my understanding correct?
The OD-record is not the same as a record in the database and it can't exist without an entity that has the record assigned.
So if you delete the OD-record, the Map-ObjectData is removed from the geometry-object.
If you delete the DBText from the drawing then the OD-record is gone also (as it can't exist without an object it's assigned to)
Now we have to make sure what wording is used (soory I'm not english-native speaking)
One is the geomtry-object TEXT (or DatabaseServices.DBText), if you delete it (command _ERASE and click onto the object) then it's gone from the drawing.
The other option is the content if the text-object (the string). If you select the text-object and remove the characters from the content of the geometry object ==> then yes, the geometry object stays in the drawing, but it's not visible (as there are no more characters to be displayed) and so it's also not selectable. And to be honest: this would be the worst way to remove text from a drawing, because the drawing-size is high even if you don't see any objects. I would suggest never to use this way.
I hope that makes it clear now (and I have described it in a readable way).
You have now four options (imho):
1)
2)
3)
4)
1) is a stable way and should be quite fast/needs Map to work
2) is a stable way, not so fast as you have to scan for objects having the correct ID in the OD-records/needs Map to work
3) is critical as it might find other text-objects then. Ff the structure is as clear as your sample drawing, than no problem, but if there are more textobjects within this polyline, and maybe on the same layer, it could get problematic. But it does not need Map (if that is an advantage).
4) same critical as 3 + you have to make sure that the text-objects is on screen before creating a selection. That may sound slower first. But if you erase the polyline by manual selection then you don't need the zoom as you are alread there. Depends on the needs. Needs no Map.
HTH, - alfred -
Thanks a lot for the detailed description, it would clear so many concepts in one go.
Here I am pasting the code where I have selected the objects on the dwg files as -
Once selected I am deleting the polyline.
But before that I am trying to get the OD:DBLINK, I am getting the value but not able to delete it.
In the same way, could you please guide me the code how can I scan for the value "Text" in the properties window?
The value for "Text" is fixed for one rectangle-polyline, but different for all the rectangle-polylines.
Dim odTable As Autodesk.Gis.Map.ObjectData.Table
Dim odTables As Autodesk.Gis.Map.ObjectData.Tables
Dim hs As HostApplicationServices = HostApplicationServices.Current
Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection()
odTables = HostMapApplicationServices.Application.ActiveProject.ODTables
Try
acObjIdColl.Add(tObjID)
For Each id As ObjectId In acObjIdColl
'Dim tCurve As Curve = TryCast(tTrAct.GetObject(id, OpenMode.ForWrite), Curve)
Next
End If
Next
Does that help?
<Autodesk.AutoCAD.Runtime.CommandMethod("ADESK_eraseText")> _ Public Shared Sub eraseText() Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager Dim acDoc As Document = acDocMgr.MdiActiveDocument Dim tSearchStr As String = "1C109" 'take your string here 'define a filter for objecttypes to be selectable 'we define now "TEXT" as objecttype to search and the content/value of the text 'and define only to search in model-space Dim tFilter As SelectionFilter = New SelectionFilter(New TypedValue() _ {New TypedValue(DxfCode.Start, "*TEXT*"), _ New TypedValue(DxfCode.Text, tSearchStr), _ New TypedValue(DxfCode.LayoutName, "Model")}) 'now get the selection Dim tSelSetRes As PromptSelectionResult = acDoc.Editor.SelectAll(tFilter) If (tSelSetRes IsNot Nothing) AndAlso (tSelSetRes.Status = PromptStatus.OK) AndAlso (tSelSetRes.Value.Count = 1) Then Dim tTrAct As Transaction = Nothing Try tTrAct = acDoc.TransactionManager.StartTransaction Dim tObjID As ObjectId = tSelSetRes.Value.GetObjectIds(0) Dim tTxtEnt As DBText = CType(tTrAct.GetObject(tObjID, OpenMode.ForWrite), DBText) tTxtEnt.Erase() tTrAct.Commit() Catch ex As Exception 'something happend MsgBox("Unknown error: " & ex.Message & vbNewLine & ex.StackTrace) Finally If tTrAct IsNot Nothing Then tTrAct.Dispose() : tTrAct = Nothing End Try Else 'send message to user MsgBox("no DBText (or more than one) with content " & tSearchStr & " found in ModelSpace") End If End Sub
- alfred -
