HELLO
I'm having trouble using cleanup drawing with visual lisp.
Annex follows lisp file and code in the same problem and asking to join polylines after performing segmentation and delete duplicates some segments are not together.
Thanks if anyone can help me
Hi
From the help:
Note
This functionality is for drawing objects only. There is no equivalent for geospatial feature data.
For best results, run cleanup actions individually or with a minimum of other actions.
Even running your cleanup actions via the dialog will give you the same result, so there is nothing wrong with your code.
If you run the Dissolve pseudo nodes separatly, it will work, so you would be bette of changing your code to do the same.
Luc
