AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Can't query entitytype notequal
2 REPLIES 2
fieldguy
487 Views, 2 Replies
Using the code below, when I change conditionoperator to conditionnotequal, it generates a map exception.  Conditionequal works correctly.  What do I need to change to get entitytype notequal to work?
This is Autocad Map 3D 2011 64 bit.
<CommandMethod("q10")> _
    Sub q_10()
        Dim prjModel As ProjectModel = HostMapApplicationServices.Application.ActiveProject
        prjModel.Options.MarkObjectsForEditingWithoutPrompting = True
        Dim dwgset As DrawingSet = prjModel.DrawingSet
        dwgset.AttachDrawing("any dwg file with text and lines")
        Dim qryModel As QueryModel = prjModel.CurQuery
        qryModel.Mode = QueryType.QueryDraw
        qryModel.Clear()
        Dim qryRoot As QueryBranch = QueryBranch.Create()
        'properties
        Dim propcond As PropertyCondition = New PropertyCondition()
        propcond.JoinOperator = JoinOperator.OperatorAnd
        propcond.ConditionOperator = ConditionOperator.ConditionNotEqual
        propcond.PropertyType = PropertyType.EntityType
        propcond.Value = "TEXT"
        Dim qbproperty As QueryBranch = QueryBranch.Create()
        qbproperty.AppendOperand(propcond)
        qryRoot.AppendOperand(qbproperty)
        qryModel.Define(qryRoot)
        Dim queriedobjids As ObjectIdCollection = qryModel.Execute(dwgset)
    End Sub
2 REPLIES 2
subpartner
in reply to: fieldguy
We noticed this issue and logged a change request about it.
I am sorry for any inconveniences.
fieldguy
in reply to: subpartner
Thanks.  I found 2 work arounds.
External query still works - set it up manually and save it.  Then use prjModel.LoadExternalQuery(pathtolspfile).
Or, save and close the queried data and use readdwgfile to make changes (very fast).
”Boost
