Using the code below, when I change conditionoperator to conditionnotequal, it generates a map exception. Conditionequal works correctly. What do I need to change to get entitytype notequal to work?
This is Autocad Map 3D 2011 64 bit.
<CommandMethod("q10")> _ Sub q_10() Dim prjModel As ProjectModel = HostMapApplicationServices.Application.ActiveProject prjModel.Options.MarkObjectsForEditingWithoutPrompting = True Dim dwgset As DrawingSet = prjModel.DrawingSet dwgset.AttachDrawing("any dwg file with text and lines") Dim qryModel As QueryModel = prjModel.CurQuery qryModel.Mode = QueryType.QueryDraw qryModel.Clear() Dim qryRoot As QueryBranch = QueryBranch.Create() 'properties Dim propcond As PropertyCondition = New PropertyCondition() propcond.JoinOperator = JoinOperator.OperatorAnd propcond.ConditionOperator = ConditionOperator.ConditionNotEqual propcond.PropertyType = PropertyType.EntityType propcond.Value = "TEXT" Dim qbproperty As QueryBranch = QueryBranch.Create() qbproperty.AppendOperand(propcond) qryRoot.AppendOperand(qbproperty) qryModel.Define(qryRoot) ' Dim queriedobjids As ObjectIdCollection = qryModel.Execute(dwgset) End Sub
We noticed this issue and logged a change request about it.
I am sorry for any inconveniences.
Thanks. I found 2 work arounds.
External query still works - set it up manually and save it. Then use prjModel.LoadExternalQuery(pathtolspfile).
Or, save and close the queried data and use readdwgfile to make changes (very fast).
