try this
;;; HATCHB.LSP
;;; Recreates hatch boundary by selecting a hatch
;;; Boundary is created in current layer/color/linetype in WCS
;;; By Jimmy B
;;; e-mail: cadman@yesbox.net
;;; 2000-02-12 - First release
;;; 2000-03-27 - Counterclockwise arc's and ellipse's fixed
;;; Objects created joined to lwpolyline if possible
;;; Error-handling, undo of command
;;; Can handle PLINETYPE = 0,1,2
;;; 2000-03-30 - Integrating hatchb and hatchb14
;;; Selection of many hatches
;;; Splines supported if closed.
;;; Tested on AutoCAD 2000
;;; should be working on older versions too.
(defun c:hb () (c:hatchb)) ; this line can be commented out if there is an
existing command called hb
(defun c:hatchb (/ es blay ed1 ed2 loops1 bptf part
et noe plist ic bul nr ang1 ang2 obj
*ModelSpace* *PaperSpace*
space cw errexit undox olderr oldcmdecho ss1 lastent en1 en2 ss
lwp
list->variantArray 3dPoint->2dPoint A2k ent i ss2
knot-list controlpoint-list kn cn pos
(setq A2k (wcmatch (getvar "ACADVER") "15*"))
(if A2k
(defun list->variantArray (ptsList / arraySpace sArray)
(setq arraySpace
(vlax-make-safearray
vlax-vbdouble
(cons 0 (- (length ptsList) 1))
(setq sArray (vlax-safearray-fill arraySpace ptsList))
(vlax-make-variant sArray)
(if A2k
(defun 3dPoint->2dPoint (3dpt)
(list (float (car 3dpt)) (float (cadr 3dpt)))
(defun errexit (s)
(princ "\nError: ")
(princ s)
(restore)
(defun undox ()
(command "._ucs" "_p")
(command "._undo" "_E")
(setvar "cmdecho" oldcmdecho)
(setq *error* olderr)
(princ)
(setq olderr *error*
restore undox
*error* errexit
(setq oldcmdecho (getvar "cmdecho"))
(setvar "cmdecho" 0)
(command "._UNDO" "_BE")
(if A2k (progn
(vl-load-com)
(setq *ModelSpace* (vla-get-ModelSpace
(vla-get-ActiveDocument (vlax-get-acad-object))
*PaperSpace* (vla-get-PaperSpace
(if (/= (setq ss2 (ssget '((0 . "HATCH")))) nil)
(progn
(setq i 0)
(while (setq ent (ssname ss2 i))
(setq ed1 (entget ent))
(if (not (equal (assoc 210 ed1) '(210 0.0 0.0 1.0))) (princ "\nHatch
not in WCS!"))
(command "._ucs" "_w")
(setq loops1 (cdr (assoc 91 ed1))) ; number of boundary paths (loops)
(if (and A2k (= (strcase (cdr (assoc 410 ed1))) "MODEL"))
(setq space *ModelSpace*)
(setq space *PaperSpace*)
(repeat loops1
(setq ed1 (member (assoc 92 ed1) ed1))
(setq bptf (cdr (car ed1))) ; boundary path type flag
(setq ic (cdr (assoc 73 ed1))) ; is closed
(setq noe (cdr (assoc 93 ed1))) ; number of edges
(setq ed1 (member (assoc 72 ed1) ed1))
(setq bul (cdr (car ed1))) ; bulge
(setq plist nil)
(setq blist nil)
(cond
((> (boole 1 bptf 2) 0) ; polyline
(repeat noe
(setq ed1 (member (assoc 10 (cdr ed1)) ed1))
(setq plist (append plist (list (cdr (assoc 10 ed1)))))
(setq blist (append blist
(if (> bul 0)
(list (cdr (assoc 42 ed1)))
nil
(if A2k (progn
(setq polypoints
(apply 'append
(mapcar '3dPoint->2dPoint plist)
(setq VLADataPts (list->variantArray polypoints))
(setq obj (vla-addLightweightPolyline space VLADataPts))
(setq nr 0)
(repeat (length blist)
(if (/= (nth nr blist) 0)
(vla-setBulge obj nr (nth nr blist))
(setq nr (1+ nr))
(if (= ic 1)
(vla-put-closed obj T)
(progn
(if (= ic 1)
(entmake '((0 . "POLYLINE") (66 . 1) (70 . 1)))
(entmake '((0 . "POLYLINE") (66 . 1)))
(setq nr 0)
(repeat (length plist)
(if (= bul 0)
(entmake (list (cons 0 "VERTEX")
(cons 10 (nth nr plist))
(cons 42 (nth nr blist))
(setq nr (1+ nr))
(entmake '((0 . "SEQEND")))
(t ; not polyline
(setq lastent (entlast))
(setq lwp T)
(repeat noe
(setq et (cdr (assoc 72 ed1)))
(cond
((= et 1) ; line
(if A2k
(vla-AddLine
space
(vlax-3d-point (cdr (assoc 10 ed1)))
(vlax-3d-point (cdr (assoc 11 ed1)))
(entmake
(list (cons 0 "LINE") (assoc 10 ed1) (assoc 11 ed1))
(setq ed1 (cddr ed1))
((= et 2) ; circular arc
(setq ang1 (cdr (assoc 50 ed1)))
(setq ang2 (cdr (assoc 51 ed1)))
(setq cw (cdr (assoc 73 ed1)))
(if (equal ang2 6.28319 0.00001)
(progn
(if A2k
(vla-AddCircle
space
(cdr (assoc 40 ed1))
(entmake (list (cons 0 "CIRCLE")
(assoc 10 ed1)
(assoc 40 ed1)
(setq lwp nil)
(if A2k
(vla-AddArc
space
(if (= cw 0)
(- 0 ang2)
ang1
(if (= cw 0)
(- 0 ang1)
ang2
(entmake (list (cons 0 "ARC")
(assoc 10 ed1)
(assoc 40 ed1)
(cons 50
(if (= cw 0)
(- 0 ang2)
ang1
(cons 51
(if (= cw 0)
(- 0 ang1)
ang2
(setq ed1 (cddddr ed1))
((= et 3) ; elliptic arc
(if A2k (progn
(setq obj (vla-AddEllipse
space
(vla-put-startangle obj (if (= cw 0) (- 0 ang2) ang1))
(vla-put-endangle obj (if (= cw 0) (- 0 ang1) ang2))
(princ "\nElliptic arc not supported!")
(setq lwp nil)
((= et 4) ; spline
(setq ed1 (member (assoc 94 (cdr ed1)) ed1))
(setq knot-list nil)
(setq controlpoint-list nil)
(setq kn (cdr (assoc 95 ed1)))
(setq cn (cdr (assoc 96 ed1)))
(setq pos (vl-position (assoc 40 ed1) ed1))
(repeat kn
(setq knot-list (cons (cons 40 (cdr (nth pos ed1)))
knot-list))
(setq pos (1+ pos))
(setq pos (vl-position (assoc 10 ed1) ed1))
(repeat cn
(setq controlpoint-list (cons (cons 10 (cdr (nth pos
ed1))) controlpoint-list))
(setq pos (1+ pos))
(setq knot-list (reverse knot-list))
(setq controlpoint-list (reverse controlpoint-list))
(entmake (append
(list '(0 . "SPLINE"))
(list (cons 100 "AcDbEntity"))
(list (cons 100 "AcDbSpline"))
(list (cons 70 (+ 1 8 (* 2 (cdr (assoc 74
ed1))) (* 4 (cdr (assoc 73 ed1))))))
(list (cons 71 (cdr (assoc 94 ed1))))
(list (cons 72 kn))
(list (cons 73 cn))
knot-list
controlpoint-list
(setq ed1 (member (assoc 10 ed1) ed1))
(setq lwp nil)
) ; end cond
) ; end repeat noe
(if lwp (progn
(setq en1 (entnext lastent))
(setq ss (ssadd))
(ssadd en1 ss)
(while (setq en2 (entnext en1))
(ssadd en2 ss)
(setq en1 en2)
(command "_.pedit" (entlast) "_Y" "_J" ss "" "")
) ; end t
) ; end cond
) ; end repeat loops1
(setq i (1+ i))
(restore)
(princ)
