AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Autodesk.Gis.Map.ObjectData.FieldDefinition.SetDefaultValue
1 REPLY 1
JohnDutz
1295 Views, 1 Reply
The following VB code, taken almost verbatim from the Map 3D Object ARX .Net Developer's Guide, doesn't compile for Map 3D 2014 (didn't test it for other versions).
Here's the compiler error:
Error 10 'SetDefaultValue' is not a member of 'Autodesk.Gis.Map.ObjectData.FieldDefinition'. C:\Users\jdutz\Documents\Visual Studio Projects\C3D_2014\MH_ParcelTools\ClassLibrary2\Class1.vb 17 9 ClassLibrary2
The error appears to be because the SetDefaultValue method isn't defined.  Is there a workaround?
Imports Autodesk.Gis.Map
Imports Autodesk.Gis.Map.Project
Imports Autodesk.Gis.Map.ObjectData
Public Class Class1
    Private Sub Sub1()
        Dim mapApp As MapApplication
        mapApp = HostMapApplicationServices.Application
        Dim fieldDefs As ObjectData.FieldDefinitions
        fieldDefs = _
          mapApp.ActiveProject.MapUtility.NewODFieldDefinitions()
        Dim def1 As ObjectData.FieldDefinition
        def1 = fieldDefs.Add("FIRST_FIELD", "Owner name", _
          Autodesk.Gis.Map.Constants.DataType.Character, 0)
        def1.SetDefaultValue("A")
        Dim def2 As ObjectData.FieldDefinition
        def2 = fieldDefs.Add("SECOND_FIELD", "Assessment year", _
          Autodesk.Gis.Map.Constants.DataType.Integer, 1)
        def2.SetDefaultValue(0)
    End Sub
End Class
1 REPLY 1
norman.yuan
in reply to: JohnDutz
I think the sample code from AutoCAD Map ObjectARX SDK's document/dev. guide is out-dated. The documentation on AutoCAD Map development has been particularly known for its not being updated.
The oldest AutoCAD Map version I currently has access is AutoCAD Map 2012, and indeed the ObjectData.FieldDefinition class does not have the method SetDefaultValue(). This method must have been there when first AutoCAD Map .NET API avialble in Map 2006 and was removed in later version.
Anyway, to create a FieldDefinition with default value, you can use FieldDefinition's static method Create() and then add the FieldDefinition into the FieldDefinitions collection:
Dim field As FieldDefinition= _
    FieldDefinition.Create("MyField1","This is the field for...", "This is default text value") ''The last parameter could be String, Integer, Doule...
MyOdTable.FieldDefinitions.AddColumn(field,0)
Norman Yuan
Drive CAD With Code
”Boost
