AutoCAD Map 3D Developer
Welcome to Autodeskā€™s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
AutoCad Map 3D 2014 Data Table
1 REPLY 1
lweiss
303 Views, 1 Reply
I have been working with some GIS data in the form of SHP files in autocad map 3D 2014. On one of my layers I have started getting "Feature was not saved in the targer feature source" when I try to check in my data. In total there are 20 errors in the data table, all of which were features I deleted. They all have a featID of null and I cannot remove them from the data table. I need to fix these errors without going back and starting over. Any ideas?
I did see this question for 2011 version However i'm unable to find the task menu that was described for that fix.
Tags (1)
1 REPLY 1
kalman_albert
in reply to: lweiss
Close Map. Delete all files from MapCache directory, you can find it
in Map -> Options-> System
something like  "ProgramData\Autodesk\Autodesk AutoCAD Map 3D 2014\R19.1\MapCache\"
Delete idx file from sHP directory. Try again. Albert
"Nothing will ever be as it was!"
ā€Boost
