Why can't I find a LISP command reference for Map 3d in Map 3D 2014?
In previous versions I used ACMAPLISP.CHM, but AutoDesk chose to go with a web-based help system which, apparently doesn't include LISP support for ADE functions. I have been limping along using the CHM file, but when I was upgraded to Windows 7 the ability to read this file type went out the window.
Has Autodesk truly abandoned me?
Thanks for any help you can give me.
J Leavitt
No, just a question of settings 😉
In Windows Explorer right click onto the CHM file ==> properties ==> security/unblock (>>>look here for details<<<).
- alfred -
Thank you for your help, but the UNBLOCK button does not come up on the dialog.
J Leavitt
on a CHM, right-clic, open with... and select HH.EXE in c:\Windows
Olivier
