Hello all,
I am trying to xref a file in and when I select open through _XATTACH nothing happens. No subsequent dialog box opens up asking me to choose location, rotation, attach/bind, etc. The command just dies and I am back in my dwg.
Any thoughts?
Tap F2 after you try and is there anything at the Command line unusual?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
This is what I get when I hit F2.
Yes, I have tried to evoke the command through toolbar, typing XREF, typing _XATTACH
All the same result. It is as if the command just cancels out. Also, this is not file specific and I can attach images. The problem only occurs when I try dwgs
Couple of clarification questions:
Did you change from two to one monitors perhaps?
Or screen resolution?
Do you get back to the command line, or does LT act as if it is frozen and you have to ESC to get back?
have you restarted Windows?
What changed recently, a new PC? a new Windows log-in? Add or remove software? Autodesk software?
Have you tried a Windows Restore back to a day or week or month it all worked?
have you tried a repair reinstall of LT as a last resort?
It's probably your XREF window that's obscurred. This just happened in our office and we figured it out.
If you have your PROPERTIES and/or TOOLPALETTES windows docked to the sides or bottom of your screen, move 'em out towards the middle, and you'll probably see a tiny bar of a window that is your XREF window. Bring that out and update its settings to just float, and then put your PROPERTIES and/or TOOLPALETTES windows back where they belong. 🙂
