Hi all, if anyone has a moment, could you tell me, what if any scope does Autocad LT have with XDATA. Can and how do you access/edit xdata in autocadLT? and what commands can be used in AutocadLT?
Thanks Sam
Solved by pendean. Go to Solution.
Thanks for the reply Dean. Specifically my client has asked that some "xdata" be attached to building entities with (as far as I can gather) a structure number. Cheers
Sam
Sadly your client will need to pony-up +/-$4000 per seat for full AutoCAD, perhaps even +/-$5000 for AutoCAD Architecture or +/-$6000 for REVIT for that ability.
In LT, if it will suffice, blocks/attributes or hyperlinked objects might be an acceptable workaround.
