AutoCAD LT General Discussion
pendean
Message 11 of 16 (471 Views)
Re: x-clip boundary
12-06-2011 12:49 PM in reply to: cdavis7254
XCLIPFRAME, set it to 1
CLIP command, select each frame then select the DELETE option.
Repeat for each frame until they are all gone.
Too long a process? For a mere $4000 you can upgrade to full AutoCAD and someone can write you a lisp to speed up the process.
>>>...That brings up the question of why is there a boundary around a block...<<<
Ask the file creator why they needed to XCLIP each outlet: it's a deliberate not an accidental process.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Distinguished Contributor
cdavis7254
Message 12 of 16 (467 Views)
Re: x-clip boundary
12-06-2011 12:55 PM in reply to: pendean
Thanks, I'm stuck with the long way.  We can't ask the creator of the clips about it as his company has been removed from the project, so they aren't being very helpfull.
Johneng
Message 13 of 16 (462 Views)
Re: x-clip boundary
12-06-2011 01:57 PM in reply to: pendean
Sorry Dean I was trying to reply to the OP
cdavis7254
I am using 2010LT so I can't test this on 2012LT. On 2012LT when you type XCLIP on the command line does it promt you for Select objects  or does it prompt you to Select Object to clip. If you are prompted for Select objects type ALL on the command line hit enter twice then d and enter.
heinsite
Message 14 of 16 (448 Views)
Re: x-clip boundary
12-07-2011 01:14 AM in reply to: pendean
This example doesn't need a $4k upgrade or LISP routine at all.  If you just want the boxes to go away during navigation the solution can be accomplished in one quick step (I used AutoCAD LT 2012).
Simply select all of the blocks in the file, type XCLIP at the command line, and turn them OFF, or DELETE them if you wish.  You're done.  In a more complicated drawing with other objects something like QSelect might be required to isolate the blocks with clip boundaries showing, but once you have them selected it's still just the one step.
Dave.
Dave Hein, P.E.
cdavis7254
Message 15 of 16 (442 Views)
Re: x-clip boundary
12-07-2011 05:04 AM in reply to: heinsite
pendean
Message 16 of 16 (439 Views)
Re: x-clip boundary
12-07-2011 05:59 AM in reply to: heinsite
DELETE is the option the OP needs, OFF was the problem: thanks for the follow up.
