I have encounter a time delay response on AutoCAD LT 2015 while working from a cloud server. It does not seems to bee working in real time. Please help/advise!!!!
need more info
Whose cloud server?
what does not working in real time mean?
if you move the file locally does the problem go away?
DarrenP
have you run this by your I.T person?
this sounds more like a network issue than an Autocad issue
i suggest as a test Install Autocad locally see if the problem still happens
DarrenP
Since the AutoCAD resides in the server can we still install it locally evethough is one license?
I woudl like to tested and see if the delay setback is from the cloud virtual connection.
you can install it as a trial
DarrenP
