I've been using an older (early 00's) version of LT and it is adequate for my needs, especially now that I'm retired. Problem is: with Windows no longer supporting XP, plus my having an older machine, I purchased a new HP desktop running Windows 8. When setting it up, I discovered that my LT software would not run on Windows 8. I hate to keep the old machine around just to run LT but other than that, do I have any options to continue using my versions of LT? Being retired, updating to a newer version is probably not financially feasible. Any suggestions would be appreciated.
One solution that you might not like to hear is that you can probably downgrade to Windows 7, but before doing that check that the AutoCAD version you have works on Windows 7! If you let us know which version it is we might be able to comment further.
http://www.microsoft.com/OEM/en/licensing/sblicensing/Pages/downgrade_rights.aspx#fbid=GBNs8qBd9Yj
It may not be the solution but thought it was worth a mention!
