I saved my drawings to plot file pdf. When I try to view drawing from where it is saved on free agent drive I cannot see it when opened ?? please help !
You say Save a drawing as PDF.
Are you trying to open the Drawing using AutoCAD?
If so then no since AutoCAD is not a PDF Viewer.
If you double click the PDF then it should open in your Adobe or Foxit or whatever viewer as any PDF does.
If this happens and there is no information in the PDF then somehting is wrong with your plotting procedures.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
No it is a 1 KB file and has no information.
Attached is what you sent me, that I modified, plotted to PDF using DWG to PDF from the Plot dialog
