AutoCAD LT General Discussion
6 Kudos
Post 1 of 6
Where to set the Fade Control of Locked Layers
2395 Views, 5 Replies
12-10-2013 05:36 AM
Can you advise where is the setting to change the Fade Control when you lock a layer?
(It is not the same as the Fade Control of the External References in the Display tag of the Options dialog.  I know that one and I am awere of this one.)
The one that I want to know is of the locked layers.  When I lock a layer, the objects in the layer fade.
Thanks in advance.
It is on the Ribbon:smileysurprised:. I use classic so I never looked for it there.
Distinguished Mentor
81 Kudos
Post 2 of 6
Re: Where to set the Fade Control of Locked Layers
12-10-2013 05:56 AM in reply to: octavio2
Hi, the command is LAYLOCKFADECTL.
6 Kudos
Post 3 of 6
12-10-2013 06:05 AM in reply to: octavio2
Thanks.
Is this setting not available also somewhere easy to find or to set location like in the Options dialog or in the Menu bar or in the Ribbon?
We use AutoCAD Lite 2013.
81 Kudos
Post 4 of 6
12-10-2013 06:14 AM in reply to: octavio2
If it is, I haven't found it. It's one of those commands that I only use when I update from one year to the next so I have it written down on my cheat sheet:smileywink:
81 Kudos
Post 5 of 6
12-10-2013 06:41 AM in reply to: octavio2
6 Kudos
Post 6 of 6
12-10-2013 09:35 AM in reply to: octavio2
Thanks for your help, sthompsom.
