AutoCAD LT General Discussion
Distinguished Contributor
architec-tor
Message 1 of 7 (637 Views)
When opening a drawing, AutoCAD automatically creates a new drawing
637 Views, 6 Replies
11-16-2011 11:19 PM
When I open an drawing, AutoCAD opens *two* drawings, the one I wanted *plus* a new one (called drawing 1.)
Why does this happen and can it be prevented?
Thank you!
AutoCAD LT 2010
Windows 7
*Expert Elite*
Charles_Shade
Message 2 of 7 (632 Views)
Re: When opening a drawing, AutoCAD automatically creates a new drawing
11-17-2011 05:27 AM in reply to: architec-tor
Are you clicking on a drawing file and having AutoCAD Start from the drawing calling for CAD to open?
Or are you Starting AutoCAD and then opening a drawing and having this happen?
The former could be normal behavior.
The latter is a little funky.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
architec-tor
Message 3 of 7 (626 Views)
11-17-2011 07:14 PM in reply to: Charles_Shade
I click directly on an existing drawing file (plan.dwg for example) -- NOT opening up AutoCAD prior top selecting a drawing..
When I click on this drawing a *new* drawing is automatically created first called "drawing1.dwg". After this new drawing is created then my target drawing opens next.
Opening up 4 separate drawings will result in 4 new drawings I have to delete.
Thanks for your help!
*Expert Elite*
Charles_Shade
Message 4 of 7 (621 Views)
11-18-2011 05:26 AM in reply to: architec-tor
That is normal behavior.
You need to read up on STARTUP
Also:
OPTIONS, Files tab, Template Settings, Drawing Template File Location: Remove the entry here if it points to a file.
architec-tor
Message 5 of 7 (609 Views)
11-19-2011 12:30 PM in reply to: Charles_Shade
I managed to chang the settings to avoid a new drawing from being created, but a separate version of AutoCAD is opening up anyway *without* a drawing (as well as the target drawing I do want opened.)
Is there a way to avoid having AutoCAD open up twice for each time I want to open a single drawing?
*Expert Elite*
Charles_Shade
Message 6 of 7 (599 Views)
11-21-2011 05:20 AM in reply to: architec-tor
SDI variable set to zero?
*Expert Elite*
pendean
Message 7 of 7 (597 Views)
11-21-2011 05:37 AM in reply to: architec-tor
What "settings" did you change exactly? That's probably the answer you seek.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
