AutoCAD LT Forum
When opening a drawing, AutoCAD automatically creates a new drawing
9 REPLIES 9
Message 1 of 10
architec-tor
3573 Views, 9 Replies
When I open an drawing, AutoCAD opens *two* drawings, the one I wanted *plus* a new one (called drawing 1.)
Why does this happen and can it be prevented?
Thank you!
AutoCAD LT 2010
Windows 7
9 REPLIES 9
Message 2 of 10
Are you clicking on a drawing file and having AutoCAD Start from the drawing calling for CAD to open?
Or are you Starting AutoCAD and then opening a drawing and having this happen?
The former could be normal behavior.
The latter is a little funky.
Message 3 of 10
I click directly on an existing drawing file (plan.dwg for example) -- NOT opening up AutoCAD prior top selecting a drawing..
When I click on this drawing a *new* drawing is automatically created first called "drawing1.dwg". After this new drawing is created then my target drawing opens next.
Opening up 4 separate drawings will result in 4 new drawings I have to delete.
Thanks for your help!
Message 4 of 10
That is normal behavior.
You need to read up on STARTUP
Also:
OPTIONS, Files tab, Template Settings, Drawing Template File Location: Remove the entry here if it points to a file.
Message 5 of 10
I managed to chang the settings to avoid a new drawing from being created, but a separate version of AutoCAD is opening up anyway *without* a drawing (as well as the target drawing I do want opened.)
Is there a way to avoid having AutoCAD open up twice for each time I want to open a single drawing?
Message 6 of 10
Message 7 of 10
pendean
in reply to: architec-tor
What "settings" did you change exactly? That's probably the answer you seek.
Message 8 of 10
fkellogg
@architec-tor; Greetings from the future!
Here I am, in 2022, and recently upgraded to v 2022, and a new PC.
Plus I had to perform the dreaded "Reset to Default" thing, due to other issues.
I also had the annoying "Drawing1" thing, and felt there was a way to fix that.
The Options>Template File> thing suggested by @Charles_Shade worked for me.
Nanoo Nanoo!
Message 9 of 10
MarkY4FED
in reply to: pendean
I am having this same problem and have tried all of the solutions I can find for it. My startup system variable is set to 3, and I still have a drawing 1 open every time I open the program. It doesn't matter if I open it through the program shortcut or by opening a specific drawing. Do you have any suggestions?
Message 10 of 10
pendean
in reply to: MarkY4FED
@MarkY4FED If you get no other ideas from anyone else around here this week then try this https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
”Boost
