AutoCAD LT Forum
wavy or squiggle line
3 REPLIES 3
CiarAssoc
7611 Views, 3 Replies
I have tried unsuccessfully to create or make a wavy or squiggle line. Tried the rev cloud but to hard to control and can not turn on ortho.
3 REPLIES 3
in reply to: CiarAssoc
No such drawing feature in LT. Explore using PLINE and then PEDIT to a spline, or using SPLINE command for something close, but not the same. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
chisel
I do remember (many years ago) a piece of software that used to convert all straight lines to something that resembled a hand drawn line ie. squiggley!
Unfortunately I cannot remember if it was standalone (export to dxf) or acad lisp (if lisp? Is there someone that you can sent your dwgs to for conversion) Assuming that you can find the software
Good luck
Squiggle: standalone, still available, along with about a few other programs that do the same thing. You plot to HPGL or HPGL2, it does not use your DWG file. Upgrade to ADT, the command NAPKIN has always been there and does what you seek inside your DWG file. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
”Boost
