I can't see my drawings in my paper space in some pages only, neither I can click inside them, the program doesn't recognize those frames as viewports. It's weird, but if I try to print the page, it can print as normal, even I can see the drawings in the print preview.
Does anyone can help me?
I'm using Autocad LT 2013
When you select one of those frames what kind of object does the Properties window say it is?
Try typing at the Command line -vports and then choose ON from the available options. Regen the drawing.
I am just baffled at how it is possible you can't see the viewport contents yet they display in Print preview and print. Hmmm...
Post your drawing if allowed.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Without looking into it deeper, is your viewport on the defpoints layer perchance, with the zero layer off or frozen?
It just happened to me. I compared this sort of drawings with those CAN show viewports and found the problem.
You just need to change the "new VP freeze" and "VP freeze" under layers properties into the icon which has a little "sun" for the layers you wanted to see in the vport.
Hopefully this could help
I had a problem with the available viewport showing just part of my drawing. I just created a new layout. When I went to page setup on the new layout, it diplayed my entire drawing. This is a very amateur answer, but it worked for me.
I had the same problems.
i solved it by looking at my layers. Some of my layers were apparently "helplines', and these helplines didn't show in the white layout.
gr.
how did you got to know about layers being help line.. where does it show that this specific layer is helpline.
