Hi, I'm using Lt 2011 and Win 7
I have a metric drawing done on a D sheet with a Vp scale = 1:50, and everything is fine. I just received a new template from a client with a D size sheet, however in order for me to see the same drawing, I have to set the VP scale = 1:1000. I know this is a simple fix as the client template is imperial, but I can't remember how to do it (brain freeze). Any help is appreciated.
Solved by pendean. Go to Solution.
Highlight the viewport frame and check out the properties box on it. There is a scale setting option there.
HTH
DJ
The VP scale is set to 1:1000, but it needs to be 1:50. Here's a sample. The drawing is rather small, with text set to 1:50 for a 2.5mm PS txt ht. Based on the other drawings I have been doing lately, the drawing shown when you first open it should be somewhere between 1:50 and 1:100 in scale. But it's not.
"D" size is the problem? Your "B" size is 1:1000, your "D" size is correct at 1:50.
Copy your B viewport into your D layout, and it is way too teeny-tiny to be a B size. All your other layouts seem correctly sized at D size.
