our field is not updating properly.
MTEXT
(point)
J
MC
(opposite corner)
[Field via Insert>Field]
[Object, clicked viewport edge; Custom scale; Use Scale Name]
Enter
The correct scale shows. However, when we change the scale of the viewport, the original inserted scale remains the same in the field. We've also used "#"=1'" and "#=1'-0"" and "1"=#'"
Suggestions much appreciated. Our average projects consist of 40 layouts. Doing this manually is a bit time consuming. This used to work, so we're baffled.
AutoCAD LT 2009, standalone commercial license, activated.
Solved by KristinLindberg. Go to Solution.
Look up FIELDEVAL system variable in LT's HELP, and ensure DEMANDLOAD variable is not set to 2.
This is what I end up with, and have NO clue when it comes to fieldeval. also, "DEMANDLOAD" is unknown in LT.
Command: FIELDEVAL
Enter new value for FIELDEVAL <31>:
Thanks for the help. Not sure why, but today everything is back to normal.
