Hi All,
When i double click in a viewport, it automatically zooms out. It was working fine on one of my other viwports as i used my pan optiona n centered my drawing. When i went into another viwport this began to happen. Now when i go back to the viewport that was working is now doing the same thing.
Solved by jleonard. Go to Solution.
Lock your viewport(s).
You need to be inside each viewport to change the variable for it to take effect inside each and every viewport.
