I have a paperspace with two viewports. When I click on "maximize viewport" to enter the drawing space, I am taken to one of the two linked viewport areas. How can I set a specific viewport as the default to be taken to?
Jeromy
Thank you for your help! I appreciate it. If I had the extra $4000 I would probably be using Revit and not LT 2006 😉
If anyone else has this problem, I've found a solution. The default viewport is the one which was created first.
