I also have this issue and i must say that it drives me nuts, sure changing the windows 7 theme to a non aero theme gets around it, but the non aero themes are as bland and boring as a bowl of steamed rice.
Has anyone found another work around to this dynamic input issue, as i like having dynamic input on while having a reasonable theme to look at. (Call me a princess if you like)
Any news would be greatly appreciated.
Damo
@navatekltd wrote:
There is a problem with windows "Aero" themes and the Dynamic Mode inputs in Autocad 2010 LT. If you pick a "Non" Aero theme in Windows the problems go away.
I'm sure that you already have figured out the fix/workaround for this problem, but I'll just post that for others having the same problem....
~MK
Just curious if anyone found a good solution to this problem (it's been about a year since the last post).
Turning off windows aero or disabling dynamic input are not great options...
Thanks.
I just read where it seems that 2012 product line may have cleared this up.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
