AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Using AutoCAD 2005 drawings in AutoCAD LT
4 REPLIES 4
406 Views, 4 Replies
I am considering purchasing AutoCAD LT.  All my previous work is drawn in AutCAD 2005, 2D only, with xrefs.  Will I be able to use the CAD 2005 drawings easily in AutoCAD LT? Is there a lot of set-up involved or can I simply open the old drawings and keep working?  Is there a preferred version of AutoCAD LT to purchase so the CAD 2005 drawings translate without problem? Thank you.
4 REPLIES 4
steven-g
There shouldn't be a problem, why don't you download the trial version just to make sure, and also to see how you get on using the new features of Autocad, and make sure you won't be missing anything you might use, for example LT does't have the dataextract command and you can't use Lisp.
pendean
FYI: Hold off on installing SP2 for LT2015 for now: some (not all) users are reporting issues opening older DWG files when this funky update is installed. I have SP1 for LT2015 installed and I have no issues with opening older files.
in reply to: steven-g
Thanks for the info. I am not familiar with dataextract and Lisp. Hopefully, that means I don't need it. I'll test out the LT free trial and see how it goes. Best,
gail-g
in reply to: pendean
Thanks for this info.
”Boost
