I am considering purchasing AutoCAD LT. All my previous work is drawn in AutCAD 2005, 2D only, with xrefs. Will I be able to use the CAD 2005 drawings easily in AutoCAD LT? Is there a lot of set-up involved or can I simply open the old drawings and keep working? Is there a preferred version of AutoCAD LT to purchase so the CAD 2005 drawings translate without problem? Thank you.
Solved by steven-g. Go to Solution.
There shouldn't be a problem, why don't you download the trial version just to make sure, and also to see how you get on using the new features of Autocad, and make sure you won't be missing anything you might use, for example LT does't have the dataextract command and you can't use Lisp.
