AutoCAD LT Forum
Upgrade problems
4 REPLIES 4
322 Views, 4 Replies
Upgrade problems
I know, I'm crazy but not only have I upgraded to Autocad LT 2013 but I changed my computer at the same time! I seem to have everything sorted except for plot style tables - I can't find them. Does anyone know where they live?
4 REPLIES 4
pendean
Probably still on the old computer where you left them?
Otherwise elaborate, is this just a STB vs CTB issue?
Its a ctb issue. You're right I know where they are on the old computer, what I don't know is where I should copy them to on the new one.
pendean
In AutoCAD, any version, start PLOTTERMANAGER command and that folder opens right away. Copy them there.
A DWG file is either STB or CTB set, to switch it between them use CONVERTPSTYLES command.
Thank you, problem solved.
MH
”Boost
