I know, I'm crazy but not only have I upgraded to Autocad LT 2013 but I changed my computer at the same time! I seem to have everything sorted except for plot style tables - I can't find them. Does anyone know where they live?
Solved by mhomer. Go to Solution.
Solved by pendean. Go to Solution.
Its a ctb issue. You're right I know where they are on the old computer, what I don't know is where I should copy them to on the new one.
In AutoCAD, any version, start PLOTTERMANAGER command and that folder opens right away. Copy them there.
A DWG file is either STB or CTB set, to switch it between them use CONVERTPSTYLES command.
