I have a fully legal registered version of acadLT. I work with a draftsperson that mistakenly bought the student version instead of LT. Can I some how get rid of the "Student Version" stamp on drawings he has started and us I open and use on the legal version. Or can he upgrade to LT and then make the stamp go away?
The stamp is encoded into the file. The only method to remove it available to users like us is to beg a repair off a VAR (which many LT users don't have access to since they bought their copy retail) or from Autodesk directly, with pretty bad response time as I understand it.
Edited by
Discussion_Admin
The DWG file, not the application you own, is the violation: content from EDU versions may not be used for commercial gain.
It does not matter what you own, it's using that file that is the reason Autodesk could audit and fine you/your firm. Never a pretty sight, and the local publicity in your area is great ammo for your competitors.
It was the deal of the century at $129. I can't believe my luck! All you suckers that paid $800. HA!
There was a poster here a few months back that purchased thru Amazon a seat of LT and was shipped the Student Version. In this case I believe that is was a bogus seller at Amazon taking advantage of the purchaser.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
While it is "supposed" to be free, if you get it through retail channels with a disk instead of downloading from Autodesk, you may be charged a "reasonable" handling charge. People not used to the high prices for this type of software may see a charge of $50 and think that that is the real cost of LT.
I thinh he paid about what I did for my LT Upagrades. I think he may have gotten the shady retailer. I do remember the day of 139.00, long gone. Thanks
