AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Upgrade from LT 2010 to LT 2013
4 REPLIES 4
datruscott
571 Views, 4 Replies
I just installed my upgrade, and I noticed that 2010 is still present as a application (And opens as LT 2010). Is it alright if I uninstall this? Or is it required to run my 2013 upgrade.
4 REPLIES 4
Charles_Shade
in reply to: datruscott
You may uninstall the LT 2010
Make sure you have your Customizations before you do so.
If you run a Registry Cleaner after the uninstall you may strip some components of the 2013 install by accident so be wary.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
BryantRacing
I wish to upgrade from AutoCAD LT 2010 to AutoCAD LT 2013 as well. I own a full AutoCAD LT 2010 license, and I just purchased a new AutoCAD LT 2013 Upgrade license.
However my machine (a Dell/AlienWare Aurora desktop) has just been re-imaged, so all AutoCAD software has been removed/cleaned. I'm not exactly sure how to go about this installation properly.
Do I install AutoCAD LT 2010 first, then install AutoCAD LT 2013 Upgrade?
I've scoured through the web-site and can't seem to locate any specifics in regards to this specific scenario.
I appreciate your help here.
pendean
in reply to: BryantRacing
You don't need to install the old software first: but you do need the old serial number to install the 'upgrade' version.
BryantRacing
in reply to: pendean
thanks I will procede forward installing the new AutoCAD LT 2013 Upgrade package.
”Boost
