Darren, If this is still an issue try the following:
Warning!
Problems caused by improperly editing the Windows registry could render your
computer operating system unusable. Microsoft has provided a wealth of critical
information you need to know about the registry in the Microsoft Knowledge Base
at http://support.microsoft.com/support.
Use the Microsoft Registry Editor only at your own risk and only after backing
up the registry as well as the system.dat and user.dat files as outlined in
ARTICLE-ID: Q132332 "How to Back Up the Registry" in the Microsoft Knowledge
Base. Additional information about the registry is also contained in the Help
topics in the Microsoft Registry Editor.
1. Close all sessions of the Autodesk products.
2. From the Start menu (Windows), choose Run.
3. In the Open box, type regedit and choose OK.
4. In the Registry Editor, locate the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD LT\R8\ACLT-1:409\RestartTools
5. Right-click the Tool1 entry and choose Modify.
Current value for this entry is acdcframe.arx,adcenter.
6. Delete ,adcenter from the value and choose OK.
7. Exit the Registry Editor.
Teresa Rosendahl
Autodesk Product Support, Platform Technology Group
Darren Eaton wrote:
> Please help...
> Windows ME
> Intel Pentium processor
> LT2002
> My computer crashed, I got a new one, I moved all data from old to new and
> now when I try to open AutoCAD jobs I get this...
> Autocad unhandled exception Coooooo5 (access violation reading 0fffffff) at
> address 5F45E3A9h
> then I hit okay and get this message...
> ACLT has caused an error in MFC42.DLL If you continue to experience
> problems try restarting.
> Then ACLT shuts down.
> Can anyone help?
> Thanks,
> Darren
