AutoCAD LT General Discussion
New Member
banji1234
Message 1 of 5 (3,142 Views)
unhandled exception error C0000005 (Access Violation Reading 0x0144)
3142 Views, 4 Replies
01-14-2013 01:44 PM
HI i just intall autocad lt 2013 and everytime i poen the program it gives me the "unhandled exception error C0000005 (Access Violation Reading 0x0144) at adress 60c6f5bfh" now i already uninstall all the other autodesk programs and reinstall this one for second time now and i still get the same error. i try the repair but it still doesnt work; if i try to "save as" the program stops working. i can save but i dont know where is sending the file  and it also stops working if i try to close it.
thank you
*Expert Elite*
Charles_Shade
Message 2 of 5 (3,137 Views)
Re: unhandled exception error C0000005 (Access Violation Reading 0x0144)
01-14-2013 02:02 PM in reply to: banji1234
Restore the Computer to several days ago and prior to the first install.
Follw this advice from Autodesk to see if there are any stragglers in the Registry:
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Try the install again.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Active Contributor
ABielecki
Message 3 of 5 (2,780 Views)
04-05-2013 12:32 AM in reply to: banji1234
I have similar problem, and I've clear installed my software (AutoCAD LT 2012) and problem still exist. What shall I do now?
GIS
*Expert Elite*
braudpat
Message 4 of 5 (2,775 Views)
04-05-2013 05:38 AM in reply to: ABielecki
Hello
You try to install ACAD LT 2012 32 bits or 64 bits ?
On which Windows exactly ?
Before, have you some others Autodesk software running OK ?
If YES, which one ?
Bye, Pat
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
*Expert Elite*
Charles_Shade
Message 5 of 5 (2,759 Views)
04-07-2013 05:09 AM in reply to: ABielecki
You may want to get into removing and reinstalling the current .NET that is on your system as well.
REVO UNINSTALLER The free version on its most aggressive setting will get rid of all files.
Use this as the uninstall instead of Windows.
Then reinstall the AutoCAD after you have done the previous suggestions to this program as well
Remember to back up your customizations first.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
