AutoCAD LT Forum
unhandled access violation reading 0x765e045c
5 REPLIES 5
gsemple
356 Views, 5 Replies
I am getting the following error message on my Windows XP workstation running Autocad LT 2008 (single user)
Fatal Error
0x765e045c exception at 6757c8c3h
After googling and looking at other knowlege base articles, I cannot find the answer to this issue. Can anyone shed some light as to what this error message means ??
Thanks you very much
5 REPLIES 5
in reply to: gsemple
there is no answer, what you have to do is figure out what it is in LT you
do when you get it, confirm it by repeating it over and over again, then
search that problem.
If the trigger is random, as in you cannot repeat it, explore turning off
running background applications.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
WillieGillespie
AutoCAD 2008 SP1 (not LT) on Windows XP gets a similar error:
Fatal Error
0x7de3557c
Seems to be related to moving blocks? Let's start narrowing down what the problem is if others are getting the same or similar errors.
grimmbe
Fatal Error
0x7de3557c
If you have a Lenovo Client remove the Mouse Suite. In my case that fixed the Problem. I hope that helps
cpyadmin
Is anyone still having this problem? I am running AutoCAD 2008 Architecture SP1. When moving blocks, I get a Fatal Error: Unhandled Access Violation Reading 0xe8575363, Exception at 58229d65h. I am getting these 6 or 7 times a day. I believe this error is related to a memory leak problem but I'm not sure if it's hardware or software. My computer has the current video drivers and hardware cert from Autodesk. I have tried turning off hardware acceleration in 3dconfig but still the problem occurs. Can anyone help?
Charles_Shade
Try here:
http://discussion.autodesk.com/forums/category.jspa?categoryID=10
This is an LT Forum, or here:
http://usa.autodesk.com/adsk/servlet/ps/index?siteID=123112&id=2786369&linkID=9240657
Or maybe:
http://usa.autodesk.com/adsk/servlet/ps/search?la=en&siteID=123112&catID=2334116&linkID=9240657&qt=Fatal+Error%3A+Unhandled+Access+Violation+Reading+
If it's the same block maybe the block is corrupt and needs to be Recovered or Audited.
Regards, Charles Shade
”Boost
