AutoCAD LT General Discussion
New Member
gebret
Message 1 of 6 (2,015 Views)
Unhandled Access violation reading 0x0054 exception at 72c214h
2015 Views, 5 Replies
06-24-2004 10:58 AM
Three minutes after loading the AutoCAD LT the application closes and the 'Topic Title ' error message is desplayed. Any help is appreciated.
I have Pentium(R) 4 CPU 2.8GHZ Microsoft windows XP prof.
Distinguished Contributor
qfanatiq
Message 2 of 6 (2,015 Views)
Re: Unhandled Access violation reading 0x0054 exception at 72c214h
04-13-2005 08:05 AM in reply to: gebret
Just answered (or rather tried to help) on this matter, below i have cut and pasted what i typed.
Is this just when opening AutoCAD or when you are trying to open a specific drawing?
I have had man errors over the time of using AutoCAD (should start to keep a list)
In the past it has been one fo several issues.
1. Graphics compatability - solution drivers (in most cases)
2. Corupt dwg - open it on the machine that can (usually the machien the dwg originated from) then type Audit in the comand line and then Y to fix errors. Save as and choose a different name then try opening it on yours.
3. Virus and or spyware - recently had a problem with this, used adaware, spybot (also known as search and destroy). These found alot but did not help the fatel error. Eventually using Hijack This and posting on a PC proffesional forum sorted it out. Just had this same problme last night on a laptop with 3DSmax.
3. is the most unlikely.
Also a quick google search has thrown this up
Please check the following:
Have you applied the Service Pack 1 for AutoCAD 2004?
Do you have other applications running or installed lately (Cisco security agent, VPN, antivirus, etc.)?
Is your disk structure correct? Perform CHKDSK on your disk and check the TEMP folders.
Any intermittent software problems can be also caused by hardware failures.
Let me know hwo you get on or if you need any links.
Cheers.....Q
qfanatiq
Message 3 of 6 (2,015 Views)
04-13-2005 09:10 AM in reply to: gebret
Found some past posts
http://discussion.autodesk.com/thread.jspa?messageID=3912907
http://discussion.autodesk.com/thread.jspa?messageID=4176093
http://discussion.autodesk.com/thread.jspa?messageID=4747741
http://discussion.autodesk.com/thread.jspa?messageID=492221
http://discussion.autodesk.com/thread.jspa?messageID=490405
I have not read through each one, but they all seem to go into this problem deeper. There might be somethgin in them that can work this out for you.
Cheers.....Q
Active Member
Diego_G
Message 4 of 6 (2,015 Views)
04-19-2005 08:01 PM in reply to: gebret
SOLVED!!!
I restored my Win XP to a date before this problem started
and it solved it! There were two software installations that may have been the culprit:
1) something called "Software Distribution Service 2.0" which I suspect is somekind of adware/spyware
and 2) Adobe Reader 7.0
Active Member
Diego_G
Message 5 of 6 (2,015 Views)
04-20-2005 08:54 PM in reply to: gebret
Re: Fatal Error: Unhandled Access Violation Reading 0x0054 at 72c214h and 72cbc4h
I had the same problem... solved it by using Win XP System Restore. Culprit was very likely an adware/spyware program .. When you use System Restore you will be able to see all programs installed on your system... those that you don't recognize are most likely adwares.... get as close to the date when LT started crashing..
Protection: keep Win XP on High Security, avoid downloading Freeware (games, etc), or accidently clicking on Pop Up ads.
Also a good Anti-spy software is good too
New Member
AcadLearner
Message 6 of 6 (2,015 Views)
06-13-2005 08:44 AM in reply to: gebret
Hi
I had the same problem as described in this thread after a brand new install of XP SP2 and after many diagnostic reboots, the culprit was a program named "IEPK" Internet Explorer Privacy Keeper from UnH Solutions. Just disable it in msconfig and AcadLT will work like a charm.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
