AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Ungroup
2 REPLIES 2
djboer
27854 Views, 2 Replies
Ungroup
How do I un-group grouped items that does not want to un-group?
I've got a certain dwg file with a few groups.
I can't seem to un-group them.
Any suggestions?
2 REPLIES 2
in reply to: djboer
You may need to ungroup them a few times to cancel all the groups.
Make sure all the layers are on, so that it can ungroup those too.
Check the properties of the group, it may be a block, then use explode.
in reply to: djboer
CTRL+SHIFT+A to toggle off grouping. Then use List to make sure they are not
blocks.
There is a group and an ungroup command in LT: abbreviate as shortcuts,
explained in Help. Or, also explained in Help, GROUP command, the pop-up,
has an ungroup option, and -GROUP command (note the dash)> Ungroup option.
Dean Saadallah
http://LTisACAD.blogspot.com
”Boost
