Due to my misunderstanding of how the block editor works, I've created a mess. I had a simple block and deleted the entities using the block editor, so now I have an "invisible" and unselectable block in my drawing. It's listed as an unpurgeable item. When using the insert block dialog, this particular block doesn't show up in the preview, although it can be selected for insert. I'd really like to get this thing out of my drawing so that I can start the block definition over again. Any ideas?
Solved by Charles_Shade. Go to Solution.
Use QSELECT to select it by name. Delete whatever is selected and PURGE. This should clear your block out.
Please remember to check Solved if your question has been answered
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
