When I create a viewport in paper space, I cannot see any of the lines, circles, etc that I created in model space. But, I can see the PDF that I imported into model space. Any thoughts? Is there some setting that I need to change somewhere? What am I missing here?
Solved by pendean. Go to Solution.
Thanks for you input. I appreciate it.
I ended up bringing a dwg template that I use at my place of employment to see if it would work on this AutoCAD LT that I have at home. It did. I can see the model space images just fine with that template. So, it must be in my settings. I haven't looked yet, but I will bet it is a frozen layer.
I use AutoCAD (full version) at work. All of our templates at work were pre-setup prior to my working there, so I wasn't entirely sure what settings were default or not. This AutoCAD LT 2015 that I am using is something that I just loaded on my home PC for a side job that I started. Still trying to figure out how to set it all up.
Hi scott7118,
Were you able to determine if a frozen layer was indeed the issue? If not, as Dean suggested, please post your drawing so we can continue troubleshooting the display issues.
Thanks 🙂
